Manual transmission
101gunner
Hey guys, I'm about to change my manual transmission fluid and am wondering where the fill plug is. Also wondering how much fluid I will need. I drive a 2010 Toyota Tacoma 4 cylinder regular cab.
At least on my Ranger with a manual, the fill plug was a few inches directly above the drain plug. Always remove the fill plug first becauae if it is seized then you are fine because you still have oil inside.
I believe the manual has capacities listed. When filliing just fill until it pours out of the fill port.
The drain is under it. Then the fill is on the side halfway up. Only fill till it starts to come out of the side.
