So hi guys. (I know this is a long post, but for you gear heads it's a nice challenge, that said I appreciate you reading all this, I am so depressed and stressed out of my Mind over this!)
I'm still chasing this miss. I have gotten real serious now because for months it had been very distinctive and drive-able. distinctive meaning it was running absolutely perfect under 3200 RPMs so it hadnt been a issue that kept me from using the truck. I have been working on it and I took apart the Manifold to test the knock sensors, took the coils off and tested them as well as wires and plugs replaced the plugs. Put it all back together and now it runs like absolute crap at all rpms including idle.
So, here is a description of problem, codes from OBD2 scanner, list of things I've done as well as live data freeze frames thru the RPM range until it hits the hard miss... PLEASE HELP :annoyedgaah::annoyedgaah::annoyedgaah::annoyedgaah:
2002 3.4l tacoma
Symptoms: High rpm miss at excact RPM 90% of time but would move around some as I manipulated parts, but always ended up back at 3200.
Ocassionally would move into the 2400 rpm bracket, but like said went back to 3200.
Sudden change after mecanical work to now running terrible and throwing missfire codes for cylinders 1,2,4,5,6... (Why not 3?) Also code for "Random Multiple Missfire"
I have done the following.
Checked spark (inline spark tester) (OK)
Checked coils resistance they were in bottom of range but met spec just barely
Checked fuel pressure (OK)
replaced MAF sensor
Replaced Igniter (Ignition Control Module)
OHMS test Crank Position Sensor
Ohms Test camshaft position sensor
Put at TDC and verified cam pulley tabs lined up with notch in rear cam pulley cover (Timing marks on belt saying "Right Cam - Left Cam" did not line up with paint marks when at TDC, that said does that really matter as long as the tabs on the pulleys lined up with the notches as spec? the belt was replaced once way back ago buy a mechanic)
Pulled lower intake and tested Knock sensors (did find bad wiring at plugs but still tested "OK" then fixed that and then re-tested buy checking base voltage then banging on them and watching voltage spike, confirmed "OK"
Cleaned and tested fuel injectors all were actuated manually and confirmed even spray.. (Did notice two injectors wet at base after re-assembly, figured bad upper o-ring went bad from being messed with, so will have to fix that)
checked fuel pressure at fuel rail and it is at 44 PSI per spec. Was not able to test pressure at the high RPM miss cause I tested this after it started running crappy. (But would a bad fuel pump cause a high RPM miss? Is that possible, I would think it would miss in all ranges with fuel pump going bad?)
Ohms tested TPS sensor and it tested good but replaced anyway cause I suspected it. The live data shows with engine off ignition on the WOT reading is at 75%... Should the TPS be showing 100% at WOT? Maybe needs adjustment?
Inspected all vacuum hoses, do not have a vacuum test gauge kit, it's on it's way from Amazon. Once again I dont think this is it, it seems to have good vacuum, you pull a hose from intake and it kills it, put it back on it runs.
Checked all grounds
Checked alternator
changed fuel filter
tested injector plugs and harness
Did compression test. The test conditions were no throttle, just crank of engine period and read compression, all within 5% of each other. No leak down tester yet. It's in mail to me (I'm in Alaska) so for now have to wait for that, I know I probably should have checked compression at WOT right? but it met specs.
So, at this point I dont know where to go next. I'm really lost here. It was in the Dealer for 5 weeks and they couldnt figure it out. Then in the end in week 5 they said they think the water pump leaked on timing belt and cause it to jump a caug/tooth but weren't positive. I took the truck back because I was of the impression that if the belt had jumped time it would run like crap all the time, then I removed covers and put at TDC and saw that even though the belt lines didn't line up the cam pulley tabs did line up and I'm assuming the last mechanic just put the belt on without lining up the marks on the belt. But what difference would that make? All that said, the water pump is most def leaking. It's obvious and has been a good long while.
I dont know guy's I'm so lost and depressed, I swear. I'm thinking I'll re set timing just cause I dont know what else to do even though I think it's right. Also, I've heard if you dont torque that crank pulley bolt to proper torque (Like 250 ft/lbs) it can work loose and cause the crank sprocket to wobble and send incorrect info to the ECM from the CPS and cause a high RPM miss and then as it gets worse become a problem continuios not just at high RPM, possible it was that and when I was cranking it to TDC manually I loosened it up some more so it's now running like crap? Hell I dont know I'm grasping here.
Here is the Code info and Live date. See the Frames per RPM ranges...
2002 Toyota Tacoma 3.4
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refrig Mon n/a
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0300 ENG $10
Random - Multiple Misfire Detected
HISTORY
P0301 ENG $10
Cylinder 1 Misfire Detected
HISTORY
P0302 ENG $10
Cylinder 2 Misfire Detected
H
P0304 ENG $10
Cylinder 4 Misfire Detected
HISTORY
P0305 ENG $10
Cylinder 5 Misfire Detected
HISTORY
P0306 ENG $10
Cylinder 6 Misfire Detected
HISTORY
Record Data @ IDLE
FRAME: -1 TM: -3.4
MIL STATUS On
ABSLT TPS(%) 9.4
ENG SPEED(RPM) 910
CALC LOAD(%) 23.5
MAF(LB/M) 1.02
COOLANT(°F) 158
IAT(°F) 61
IGN ADV(°) 13.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
EQ RATIO11 1.000
OBD2 STAT CA
@ light acceleration in neutral
FRAME: 5 TM: 16.0
MIL STATUS On
ABSLT TPS(%) 11.4
ENG SPEED(RPM) 1513
CALC LOAD(%) 23.5
MAF(LB/M) 1.72
COOLANT(°F) 162
IAT(°F) 61
IGN ADV(°) 24.5
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
EQ RATIO11 1.000
OBD2 STAT CA
@ medium acceleration in neutral
FRAME: 6 TM: 19.2
MIL STATUS On
ABSLT TPS(%) 13.3
ENG SPEED(RPM) 2108
CALC LOAD(%) 23.9
MAF(LB/M) 2.39
COOLANT(°F) 163
IAT(°F) 61
IGN ADV(°) 31.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
EQ RATIO11 1.000
OBD2 STAT CA
@ Dead miss, cannot gain more RPM, complete MISS, Blinking
CEL and hard hard miss...
FRAME: 8 TM: 25.6
MIL STATUS On
ABSLT TPS(%) 16.1
ENG SPEED(RPM) 3071
CALC LOAD(%) 27.8
MAF(LB/M) 3.79
COOLANT(°F) 163
IAT(°F) 59
IGN ADV(°) 29.5
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
O2S12(V) 0.000
O2S11(V) 3.298
EQ RATIO11 1.000
OBD2 STAT CA
Now reducing RPMS from Hard miss at higher RPM...
FRAME: 9 TM: 28.8
MIL STATUS On
ABSLT TPS(%) 13.7
ENG SPEED(RPM) 2491
CALC LOAD(%) 20.0
MAF(LB/M) 2.18
COOLANT(°F) 165
IAT(°F) 59
IGN ADV(°) 30.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
O2S12(V) 0.000
O2S11(V) 3.298
EQ RATIO11 1.000
OBD2 STAT CA
2002 3.4l tacoma
replaced MAF sensor
Checked all grounds
Checked alternator
changed fuel filter
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refrig Mon n/a
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0300 ENG $10
HISTORY
P0301 ENG $10
HISTORY
P0302 ENG $10
H
P0304 ENG $10
HISTORY
P0305 ENG $10
HISTORY
P0306 ENG $10
HISTORY
Record Data @ IDLE
FRAME: -1 TM: -3.4
MIL STATUS On
ABSLT TPS(%) 9.4
ENG SPEED(RPM) 910
CALC LOAD(%) 23.5
MAF(LB/M) 1.02
COOLANT(°F) 158
IAT(°F) 61
IGN ADV(°) 13.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
EQ RATIO11 1.000
OBD2 STAT CA
FRAME: 5 TM: 16.0
MIL STATUS On
ABSLT TPS(%) 11.4
ENG SPEED(RPM) 1513
CALC LOAD(%) 23.5
MAF(LB/M) 1.72
COOLANT(°F) 162
IAT(°F) 61
IGN ADV(°) 24.5
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
EQ RATIO11 1.000
OBD2 STAT CA
FRAME: 6 TM: 19.2
MIL STATUS On
ABSLT TPS(%) 13.3
ENG SPEED(RPM) 2108
CALC LOAD(%) 23.9
MAF(LB/M) 2.39
COOLANT(°F) 163
IAT(°F) 61
IGN ADV(°) 31.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
EQ RATIO11 1.000
OBD2 STAT CA
FRAME: 8 TM: 25.6
MIL STATUS On
ABSLT TPS(%) 16.1
ENG SPEED(RPM) 3071
CALC LOAD(%) 27.8
MAF(LB/M) 3.79
COOLANT(°F) 163
IAT(°F) 59
IGN ADV(°) 29.5
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
O2S12(V) 0.000
O2S11(V) 3.298
EQ RATIO11 1.000
OBD2 STAT CA
FRAME: 9 TM: 28.8
MIL STATUS On
ABSLT TPS(%) 13.7
ENG SPEED(RPM) 2491
CALC LOAD(%) 20.0
MAF(LB/M) 2.18
COOLANT(°F) 165
IAT(°F) 59
IGN ADV(°) 30.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
O2S12(V) 0.000
O2S11(V) 3.298
EQ RATIO11 1.000
OBD2 STAT CA
