Rack & Pinion Power Steering Line
gwkinvest
I have a 2005 Toyota Tacoma double cab 4wd. The longest power steering line on the rack and pinion has a leak that can't be repaired.
I would like to buy the p/s line or a used rack & pinion with intact line. The p/s line is not available for purchase from Toyota separate from the rack & pinion. Other option is if anyone knows of someone with the metric fittings that could fabricate a line.
Appreciate your response!
Pick a part or junk yard. I'd try there first. Then you always have google. There has to be something out there for just the p/s line. Good luck.
