rear brakes
Discussion in 'Member Garages' started by dwayne.surrat, Dec 22, 2017.
  1. dwayne.surrat
    dwayne.surrat Well-Known Member
  3. whippersnapper02
    You will also need the proper master cylinder so you don’t lose rear braking power.
  4. Bojangles
    Bojangles Well-Known Member
    Why?
    What are the actual problems with drums?
    OR17TRD and whippersnapper02 like this.
  5. OP
    dwayne.surrat
    Disc are just easier to work on
  6. Bojangles
    For years these kits have caused decreased braking lol.
    Not sure if things have changed
  7. whippersnapper02
    Drums are fairly easy to work on. You just have to attempt it.
    Bogunn, OR17TRD and Bojangles like this.
  8. OR17TRD
    If the dealer did your brakes not that long ago and they are making noise take it back and make them fix it.
    Drums aren’t bad once you do a set. They also last a long time so it’s not like you’re doing them every couple year's.
    Bogunn and Bojangles like this.
  9. OR17TRD
    Good question.
    Bojangles likes this.
  10. Bogunn
    Yep. Drums last forever. Tried and true. Rear braking is minimal in a pickup so they do the job.
    Like @OR17TRD said, the dealership should fix them since they’re jacked up after they changed them.
    Bojangles and OR17TRD like this.
  11. OP
    dwayne.surrat
    I looked and they were done in may 2017. I’ll just wait till after Christmas and call them to get them to see what it is making the noise
