Rear Braking Vibrations 2012 Toyota Tacoma
I was wondering if anybody had similar issues with rear braking vibration at lower speeds.
Thanks!
Cant say i have.
Are you sure its the rears, as the fronts are heavily biased just like most vehicles, especially with all the plastic over our rear axles.
Does that immediately stop the vehicle if the rears are working right? It won't stop if they aren't?
One click won’t stop the truck but it will engage the rear brakes only so you can see if they are causing your vibration issue. 2 clicks may cause a lockup but that depends on wear. Just be safe about it.
