My 2019 is at 30,000 miles and it appears time for a transfer case oil change. What is a good equivalent to the Toyota part # 08885-81080 75W Oil?
I've seen Red Line and Ravenol as much less expensive alternatives. Is there a recommendation that you have?
Thank you.
Thanks
I've seen Ravenol, Red Line and Royal Purple as options but not Amsoil. Want to be sure that I am putting the correct equivalent in but not paying $180 for two quarts of Toyota brand, which is obscene.
I've heard bmw has a 75w transfer case oil, plus shell sells the equiv...both work well. At any rate you should only use that weight fluid if you live in a cold climate, or your transfer case might not operate the way it should.
