Upper Control Arm Upgrade/Replacement
@Daca_taco
I've been looking into new upper control arms since I noticed a tiny crack in one of mine. Does anyone have any opinions on total chaos, baja kits, or camburg's UCA's?
With the research that I’ve done I’d go with TC. I know nothing about Baja and the camburgs seem to have more mixed reviews. I’ve read of people replacing them with TC after running them for a while.
I kinda like the LR's (light racing) UCA's I've installed 2 of them & they are easy to do & the most detailed, easily understandable instruction sheet I've ever seen & I believe they're still adjustable as well... A lot cheaper than TC or Camburg JUST REMEMBERED : Check out Built-Rite UCA's
I'd go Light Racing unless you have extended travel stock replacement shocks and intend to wheel at a decent pace. Even then stock is mostly fine.
