Wheel offset on stock height 2017 Tacoma w/275/65R18
Discussion in 'Aftermarket Products, Reviews & Installation' started by Tacotony75, Mar 26, 2018.
  1. Tacotony75
    Tacotony75 New Member
    Got a 2017 Limited Quicksand Tacoma and was wondering what the max offset wheel I could go without lifting the truck. I am running 275/65 18.
  3. OR17TRD
    Short answer -6 offset.
  4. OR17TRD
    +30 offset if you’re going the other way. I didnt think that’s what you meant when you said max offset. I could be wrong though.
  5. OP
    Tacotony75
    Well that’s a bummer haha. Most wheels are offered in either stock or -12 offset. So I might have to go down a tire size to fit the -12 offset
  6. OR17TRD
    That’s not how that works. Most wheels offer many offsets
  7. OR17TRD
    How wide are the wheels?
  8. OP
    Tacotony75
    I should specify. The wheels I want are only offered in 1 and -12. And are 18x9
  9. OR17TRD
    +1 offset in 9” with 275/65/18 would work but you might need 5100’s in front set to 0.75” to level the truck and help clear the tires better. You can try the -12 if you want to.
    Let us know what you do and the outcome.
