wobble in front end (right) at any speed from crawl to normal?
Skip Stein
Hello All;
I have a 2007 Tacoma 4x4 with a wobble or clunk or (?) that feels like a loose wheel bearing. The wobble in the left front wheel area can be felt from a crawl to normal speeds when going over the slightest bump. Feels like a loose wheel bearing. There is no wobble in the steering wheel.
I have replaced the left front CV axle and the bearing, had the tires aligned and balanced. Did not fix. The shocks are stock TRD Toyota Bilsteins, they are not leaking. The truck has 90K plus miles.
I have had it to the dealer and local front end shop, alignment is fine. No one seems to know what it is. Help!
Any thoughts?
Jack it up under one side of the a-arm and bring the tire off the ground a inch or two. Stick a pry bar from the tire and pry up you will notice if you have any play in either the upper or lower
