it's stucken stubborn elsewhere too! Around the outer edgesHopefully that gasket will making removal easier after the next 110k miles.
I queried to timmy the toolman Toyota time YouTube presentation and he also was curious about this gasket and none of the numerous rigs he's done the brake drums has ever had this paper gasket on thereI have done a good amount of searching on the interwebs and come up blanks so far
and Yet the parts diagram shows my rig as having a gasket in the rear drum area
With a part# even
I shall Have to look deeper into it when I get the other drum offOk, here's what's going on;
If you look at the brake drum, there will be a band of rust at the edge of the working surface. When you try to pull the drum off, the shoes will get caught on it, making removal exceedingly difficult. You want to make sure to hit that rust lip with a disk grinder (sandpaper pad) before reassembling.
The "sticky brakes" problem isn't in the brake itself. Its because of the cable ends. If you look at the brake cables where they bolt onto the back of the brake, you will see that the end of the cable has an aluminum bracket. That aluminum bracket will be corroded on the inside, and possible collapsed and/or snapped off part way.
Now if you happen to have stuck brakes because of this, best way to get them unstuck is to hit the hydraulic brakes real hard a few times. In the worst case, do this AS you're trying to rock the vehicle gently. The pressure from the hydraulic brakes will pull the cable back in.
That "gasket" is irrelevant.
Helps also to back off on the brake shoe adjuster before trying to pull the rear drums.Ok, here's what's going on;
It's an extremely tight spot to get inside there with two hand tools without vEhicle sufficiently elevated off the ground!Helps also to back off on the brake shoe adjuster before trying to pull the rear drums.
Must of been his first big job.the Toyota dealer tech that advised me the truck had some sticky/crusty handbrake mechanism back in the drums and wanted to get inside there to clean, lube and adjust/inspect stuff stated he tried EVERYTHING to get the drums off.
when i had a go at it in driveway the little rubber oval plug that gives access to that adjuster wheel appeared to still have a thin layer of dried sealant onit that i was using to clean up the drum backing plates.
its like he NEVER touched that thing to back off the shoes, nothing had been disturbed
and he tried EVERYTHING...
This was in Illinois... A cold climate state per ToyotaMust of been his first big job.
Idk what cold climate has to do with this.This was in Illinois... A cold climate state per Toyota
