'00 2.4 front hub issues
dudeman32123
I was attempting to change my rotors and realized it might not be so easy as I thought it would. The rotor is attached to the hub in a fashion I am unfamiliar with. Its a 5-lug hub on a 2x4 drive train. I also fear that i might need to replace the hub as my buddy thought it would be brilliant to drill on the axle nut with an impact (against what I had told him) whilst we were putting everything back together. Does anyone know how to pull apart the hub and reassemble or where I might find the info to do so.
For future reference, all 5 lug Tacomas are 2wd.
It's a standard spindle setup. You take off the dust cover, undo the cotter pin and nut, pull the rotor off (don't forget to catch the bearing) and replace. Looks like in this case the hub bolts to the rotor.
