LanceSR54WD
its an automatic.162k miles.Carfax was perfect,nothing wrong,everything good when purchased in Feb.lately the trans slips alittle and hard shifts generally in morning.check engine light on.took to trans shop,he said trans is good.he said my truck has a MOISTURE issue maybe in the wiring harness area and said he would not recommend replacing nothing.i assume he got the 2 codes erased.1 was trans shift sensor(which I still think is the issue).the other code was a right front tire sensor,anyway started having the same issue again,got a 2nd opinion.guy drove my truck off and on for 2 wks and it didn't mess up while he was driving it.he did erase the check engine light.this is the 2nd time 2 mechanics cant find the problem.ive had 44 automatic 4x4 trucks and never had an issue---my question is-anybody else have issues with their automatic Tacoma having shift sensor code problems but transmission is good but maybe a moisture issue(I feel like I bought a lemon).Any help would be appreciated.BTW-when truck hard shifts,the CC doesn't work
