Bigislandrock
Bigislandrock
Prior to getting my 6" lift installed i considered purchasing aftermarket rear springs that can handle the loads i haul. Usually when i haul green waste its roughly 3-400lbs / camping gear plus my family 400-450lbs and now i'll also be getting a new steel bumper with tire carrier as well as a spare 33", im sure all of this will put added strain on my stock springs as prior to the lift it sagged.
Anyone do a rear spring upgrade? Add-a-leaf? Is there any manufacturers who have a 6" spring for Tacoʻs? Iʻve researched All-pro and Northwest wbo have 2-4" spring lifts. Should i go with a 2" and retain the 4" block? Id like to get rid of the block though. How does this work? Might i need shims to correct driveline with the 4" springs? Any advice, suggestions?
