....mine did that stock before i got a real alarm.Not possible with the OEM keyless entry. You need the upgraded alarm function or an aftermarket alarm.
The upgraded alarm can be programmed by thr dealer to lock in gear.
YessirDid your horn honk with key fob commands?
Yessir
I could kick the trucks tires, smack the fender, and no noise.RS3200 alarm upgrade. Plain Jane keyless just unlocked and locked your doors with the fob. Nothing auto about it except the auto lock after 30 seconds of unlocking and no doors opened.
I even left a window down, pushed fob to lock door... then reached in and opened the door with no beeping.
Did this with both sides.
It wasnt a sensor issue as the pressure switch activated the dome light and the door open light on the dash operated as it should.
But the doors locking in gear?As far as I know beeping meant nothing and horn meant alarm. It may have been different on the ealier years.
Yet no alarm sounds when doors opened while armed/locked?
