However much a bed full of snow weighs.... hahaHow much weight do folks usually but in the bed of the truck to help in traction on snow. 200lbs? 300 lbs? Thanks.
I never worry about it either.. Just flip the switch and roll.However much a bed full of snow weighs.... haha
I usually don't worry about it in a 4x4 but you could get a few sacks of sand and toss them by the tailgate if your worried.
When I lived where it snowed, I just shoveled snow into the back of my truck until it started to squat. Of course if I needed to haul something I had to shovel the show back out. But if not then it would just melt come spring.How much weight do folks usually but in the bed of the truck to help in traction on snow. 200lbs? 300 lbs? Thanks.
Cinder/cement blocks work too, and they always come in handy when not used to weigh your truck down.Used to do the same but park in a garage now where it is above freezing. Will probably get some sand bags.
Why would you want 4x4 on dry pavement? [emoji23]The rear end just seems to slip out from under it so easily. Will get some sand I suspect. Can you run on dry pavement in 4 high or do you need need to shift back and forth between 4 and 2 depending on the road? This is first modern 4x4 I've had. In my old ones you couldn't drive on dry pavement in 4 wheel drive without binding the axles. Here in Ohio with the wind the road can be snow/ice covered in spots and dry in spots. Variable as can be. Just trying to get a feel for how people handle that.
Thanks for the reply's.
What is the speed limit in 4wd high?Why would you want 4x4 on dry pavement? [emoji23]
I know what you mean.... in a straight line in between snow patches on the road, yes. If the asphalt is still wet with snow melt and you're not comfortable going to 2wd yet, it's fine. You want to take it out if you're making tighter turns though, like a parking lot that's half melted, go back to 2wd.
They're easier to work with than an NP205... but it gets pissed when you do over 60mph in 4H.... haha
60mph. LolWhat is the speed limit in 4wd high?
60mph. Lol
Like how a gooseneck trailer doesn't take weight off of the front axle compared to a bumper-pull... never put that much thought into it!Put sandbags over the rear axle, not all the way at the tailgate.
This is true as well, and I DIDNT think of that. Just the centripetal force aspect. good thunkLike how a gooseneck trailer doesn't take weight off of the front axle compared to a bumper-pull... never put that much thought into it!
I had to dumb it down for myself. [emoji23]This is true as well, and I DIDNT think of that. Just the centripetal force aspect. good thunk
