When was the last time your tires were balanced?
I had to read this 3 times to understand what the hell you where trying to say. Haha.go over bumpy road............do constant speed of 30 or so and remember that speed.
note the noise
do this again while SLIGHTLY dragging the brakes.
noise stop?
pads floating, greased shims help
diagnosis cost.......... free
heres a video this is a mild clack, sometimes it can be a lot more louder, when I changed out my front pads it went away for a while but has returned, I used OEM pads and new caliper pins,and an additional anti rattle spring on the top caliper pin but it hasn't stopped the clack, so I can live with it.
I was kinda tired and in pain.... passing a kidney stone.I had to read this 3 times to understand what the hell you where trying to say. Haha.
Same as mine, did you find out what is that.heres a video this is a mild clack, sometimes it can be a lot more louder, when I changed out my front pads it went away for a while but has returned, I used OEM pads and new caliper pins,and an additional anti rattle spring on the top caliper pin but it hasn't stopped the clack, so I can live with it.
they all do it, it will not damage the truck. its called Pad Slap you can search it on the internet.Same as mine, did you find out what is that.
