Adam Gendron
I just did my first tune up. By that I mean I replaced the plugs, wires, cleaned the MAFS, cleaned the o2 sensor, cleaned and charged the K&N filter.
I was going to do the PCV valve but I broke half of the grommet off and couldn’t get the rest so I just left it on. I don’t think there is a problem with the PCV valve anyway. When I get brave I will finish that job. I am scared the rest of the grommet will fall into the valve cover.
I also started to replace the fuel filter but when I took off the nuts on the end that goes to the tank, it seemed like something was stopping the fuel line from coming out so I just put it back. I also didn’t know how much fuel it would drop and I was in my garage at my apartment and it wasn’t seeming to stop. I did depressurization on the fuel line by unplugging the relay switch under the steering wheel as per the manual.
When I first did the tune up I got the wires mixed up. I turned the truck on and knew there was something wrong.
I got the wires figured out. But now it’s wanting to stall when in gear and the idle is a little funny. I checked the hoses for vacuum leaks. How do I figure out what’s wrong?
