Engine Idle
My 2017 TRD Sport / 3.5 Idles at about 1100 rpms in park after it is started. Even after a few minutes its still at 1100 rpms. Is this normal? It almost clanks when I put it in gear. Anyone else have a high idle.
Yeah that’s about where mine sits until it warms up. It’s normal. It’s the hot/cold start programmed into the ECU.
There was a TSB for a hard shift from drive to reverse and reverse to drive you’d notice that, it was bad, yours should have already had that fixed.
My 2017 TRD Sport / 3.5 Idles at about 1100 rpms in park after it is started. Even after a few minutes its still at 1100 rpms. Is this normal? It almost clanks when I put it in gear. Anyone else have a high idle.[/QUOT
1100 rpm is normal when you first start truck but should drop down to 600 or 700. It might take a little time . If after driving a little and when stopped at red light it should be around 5 or 600 rpm ..proving it is a automatic tranny. Hmmm can I say that word? Anyways I learned all this when I had issue with codes popping up. I replaced purge valve and rpm dropped and Gass mileage increase and codes gone.
