So...I have a 2013 double cab with the V6 (about 28k miles as of now), and I hear engine knocking at about 1500 rpm with very mild acceleration in higher gear. Took it to the dealer while it was still under warranty, they claimed everything was normal. Now, I'm no mechanic, but I've heard engine knocking before and this sure sounds like it. The knocking almost sounds like some diesel engines I've heard. My questions are: 1) is this something that will cause permanent engine damage over time, and 2) since I did take this in under warranty for this issue, will it be covered if it does indeed cause a future problem now that my warranty period has ended? Thanks for any help!
