Grease fittings
Discussion in '2016 - 2023 Toyota Tacoma' started by 24-7, Apr 11, 2022.
  1. 24-7
    24-7 Well-Known Member
    Hi everyone. Can someone tell me or show a diagram of where all the grease fitting are? I have a 2016 TRD OR 4x4 6MT DC.
    Thank you
    Phil
    Scott Wyman likes this.
  3. B-Man
    B-Man Well-Known Member
    2 on the front drive shaft. Thats it.
  4. OP
    24-7
    That's it?
  5. tacojoel
    tacojoel Well-Known Member
    Thats 2 more then on my 2020.
  6. B-Man
    Yep! Sorry! LOL
  7. OP
    24-7
    What grease do y'all recommend?
    B-Man likes this.
  8. B-Man
    I use Amsoil grease. Theres 1 and 2. Toyota recommends the 2.
  9. OP
    24-7
    I found these three
    B-Man likes this.
  10. B-Man
    Factory U-joints? Look like replacement. Factory has only two on the front drive shaft.
  11. OP
    24-7
    My driveline is all stock and I am the original owner.
    B-Man likes this.
  12. It is my opinion that all car manufactures have intentionally left grease certs out to make the front end wear out sooner so you will want to buy a new vehicle. I bought a shot needle that hooks on to the grease gun hose tip. With the needle you can stick it thru the rubber and add grease. About once every 10,000 miles is good unless you drive on a lot of wet roads. Any autoparts store stocks the needle accessory
