Ground on fog light kit 2011
Johnnytacoma
Hey, installing fog light kit on 2011 SR5 that is not prewired. The inside length of cable that goes to the fuse box and dash button includes a ground wire. Where should I attach that? Any screw not attached to per in the dash? It is too short to go back to the battery and the other stretch from the lights is linked to the negative of the battery already.
Any good ground spot should be fine. Don't overthink it, clean a spot on the frame, body, accessory mount, and use that.
