Is getting a k&n air filter or trd air filter pretty much the same effect as a CAI?
Get a cleanable filter if you want. I did, I like that if I need to I can pull it shake it get back to 80% and go if I needed to. Other wise OEM is cheap buy 8 before it makes it worth the $$$
I like aFe dry personally I wouldn’t do KnN might just be me.
Buy a scangauge2.... Record iat vs ambient temps at 45/50 mph... Base purchase on facts?
Keep scangauge, it's worth more than any intake
Oiled filters like the K&N will potentially jack up your Mass Air Flow sensor. And they can let more crap in like @whippersnapper02 said.
The 3.5 is designed to run well as is, albeit it noisy with a tick it’ll be a motor to last for years I’m sure.
Get a reusable if you want like AFE, like @OR17TRD said.
Also a scangauge or OBD2 reader isn’t a bad idea like @Bojangles said.
All good solid advice from the replies in this thread.
