Kc 3 inch led cube
jrct84
Hey guys I have a pair of led cubes and I wanna run another pair of them! I have a bracket to extend it and gonna put them there. Can I connect both pairs to one toggle switch?
As long as the max Amp and volt is compatible and you want all the lights on one switch you should be fine.
So I installed my other 2 led cubes just spliced them in and they worked great for 2 days now they don't does anyone know what would cause all of them to stop working? The fuse is fine by the way.
Process of elimination.
Replace fuse if u havent already, regardless of how it may "look".
Then if still not working, take all items out if the equation. Use a 9v battery directly to the leads on the end of the light.
If the light comes on, its ur switch or wiring i assume... if the ligjt wont come on, well.... then it would have to be a light issue and warranty time i assume.
