Maintenance
My 2018 tacoma just reached 45 000 km. I have done regular oil changes. today I changed my diff (front & rear) fluid and transfer case oil. I do tow a bit of heavy materials so I just wanted to do some preventative maintenance. I was just curious to see what other fluids I should be keeping an eye on and when to change them. I’m a bit on the cautious side and like to change fluids a little earlier then recommended. If some one wants to let me know when and what they have changed like: spark plugs, transmission fluid, coolant, etc. Thanks !
Your owner's manual/maintenance guide book will have the suggested intervals for everything.
I just got a 2006 V6 4wd manual. Is there any maintenance that needs/can done together? On my 2002 when I changed the timing belt, I changed the water pump as well because it was already torn down that far.
