I have a 4 cylinder 2004 tacoma bought used with 34,000 miles. Oil capacity for this engine is 5.8 quarts. First oil and filter change needed 3.5 quarts to fill to full mark on dip stick. Second oil and filter change also needed 3.5 quarts to fill. Now I'm worried. So far I have confirmed that the dip stick and the dip stick guide are the correct parts. Working to confirm that the oil pan is the correct. I added an additional quart of oil after the second oil change so I'm now running 4.5 quarts where the specs call for 5.8. Should the oil pan prove to be the correct one, as I suspect it will, does anyone have any suggestions.
