tacomasfordayz
So kinda long story short, got a 1999 Tacoma 4x4 In October, had the CEL pulled and didn't know it had Problems, fixed a couple things but now has the P0171 code, I know it's an lean idle condition, so far I have changed the MAF, the fuel filter, all spark plugs, air box because it had a big hole in it, pcv valve, hose from charcoal canister to air box, fuel cap, pressure sensor, fuel pump, and my timing was off and I took the belt off and adjusted it, I've checked for vacuum leaks, and I can't seem to find anything. I have problems starting sometimes but it always starts, and I have a pretty low idle at times, maybe the injectors? I'm so out of ideas I don't know what to do, I was thinking the charcoal canister, or fuel pressure regulator may be at fault, that's in advance!!
