parking light/ blinker.
Thewarriordinghy
So all magically, my right parking light and right blinker are out. is this an easy fix? its a 2007 and its stock. and how much will it cost?
Inside front turn signal/DTRL and rear turn signal: $5-6 Link
Outside parking light: $8 Link
Front:
Open the hood
Locate the bulb socket and turn the socket to unlock
Pull out the socket
Remove and replace the bulb
Place socket into the headlight and turn to lock
Rear:
Open the tailgate
Take the two screws out of the side of the tailight
Remove the taillight
Locate the bulb socket and turn to unlock
Remove the socket
Insert the socket and turn to lock
Replace taillight
Don't forget the screws
I have never changed the outside parking lights before. Try to clean the bulbs off if you touch the glass directly with your fingers. I used gloves to avoid leaving body oil on the bulbs.
