Pro grille
2018TuRD
I got a 18 trd or. Been thinking about the pro grille...can anyone point me in the right direction for one that accommodates all the safety sense nonsense??
Apparently the previous Pro Grille will work. That being the case you can order them all day for under $150 online. Just ensure the needed mounts are there before buying.
Here is an excellent write up on this exact question.
https://www.tacomaworld.com/threads/2018-trd-pro-grille-w-tss-p-radar-info-diy.530769/
Anyone know if the grille "garnish" **** is necessary??
Just installed 16/17 OE Toyota Pro grille, after first 10 min of driving collision sensor light came on for about five minutes, then went off and has not been on since(450 miles after light) so in my case no garnish needed and the grille looks much better when you can leave the insert alone and not have to install the garnish, try to go OEM on the grille better color and plastic
