Changing the fluids yesterday AM liked using the 10mm hex. One tool to do both the front and rear instead of the 10mm for the front and 24mm socket for the rear. Making things simpler.I don’t think it would matter either way. Why do you want to swap it out?
Does the front one fit the rear one? Can you find the part number for it and swap it.Changing the fluids yesterday AM liked using the 10mm hex. One tool to do both the front and rear instead of the 10mm for the front and 24mm socket for the rear. Making things simpler.
I don't know if the fronts will swap with the back........definitely not the drain plug in the front......way too big.......the fill plug for the front looks smaller too. Looked for fill/drain plugs for the rear with 10mm hex but did not find.Does the front one for the rear one? Can you find the part number for it and swap it.
Hence this thread.I don't know if the fronts will swap with the back........definitely not the drain plug in the front......way too big.......the fill plug for the front looks smaller too. Looked for fill/drain plugs for the rear with 10mm hex but did not find.
Exactly! LOLHence this thread.
Probably have to find the part number for the rear plug then figure out what size thread it has and search for that size plug/bolt with said thread and head.Exactly! LOL
I’m sure there is something out there it just won’t be OEM.Maybe they don't make the rears with 10mm hex opening..........would be nice if they did.
I might have to stay with what I've got then........I’m sure there is something out there it just won’t be OEM.
Exactly! LOL
insert comment here
