858_tacoma_guy
The guy at autozone told me it's safe to put a full bottle of seafoam into my truck lol. Is this true? And does it help MPG?
On my Ranger, I used some in the tank and some through the vacuum line. I saw no change.
So if I poured a whole bottle into my gas tank, no harm will be done..?
Anything happen? [emoji16]I tried gumout for my truck. Put the entire bottle in my truck. Let's see what happens
Maybe they like to waste money and or spend money.I'll add, you guys with newer trucks shouldn't even bother , not enough build up usually to warrant it...
I had an 85 Nissan pickup back in the 90’s that was running pretty poorly. Talked with a mechanic and he said to try a bottle of BG44K before he tore into it. This is something similar to the Sea foam. Totally cleared it up. I account this to carbon build up with a high mileage vehicle. If you have it in your area it would be something to try. Worked for me. Good luck.
Just be careful it doesn't poison the catalytic converter. letting all that crud loose into the exhaust can coat the catalyst.
To go brap brap... brapI' forgot why you guys were dumping that **** in your tanks in the first place...
