Unless your coils are bad, just get plugs. Factory Denso from the dealer. Nothing special is needed.
What you don’t want NGK on one side and Denso on the other?
Welcome to the forum. Like @whippersnapper02 said your coils are probably fine and the OEM ones used are denso and ngk. Either will work until they don’t. Unless you’re @dwayne.surrat and go 150k miles on the everlasting ones he some how got.Need recommendations for a good spark plug and coil combo
Stick with the factory coils. But replace the spark plugs withfactory Denso every 30k milesNeed recommendations for a good spark plug and coil combo
I just replaced mine as second owner and that's how it was[emoji23][emoji23]What you don’t want NGK on one side and Denso on the other?
How many miles on it?I just replaced mine as second owner and that's how it was[emoji23][emoji23]
90kHow many miles on it?
That’s a little past the recommended change if they were original. Did they look bad?
