chrismorse
Hi Guys,
First post, (2001 Tacoma 2WD, Great Truck),
My speedo, odometer and cruise control quit at the same time
From what i can find, it seems that the speed sensor may have quit.
I will check the electrical connections, rotate the drive shaft to check the variable voltage out put on the sensor.
Absent a trashed gear, it looks like the sensor is bad if no output.
BUT, looking at the on line replacements, the prices are all over the map, less than $20.00 up to almost $200.00 WTF ???
Who makes a good, durable replacement???
Or, if the gear is trashed, who makes a good replacement?? Toyota?? The original lasted almost 300,000 miles, but OEM isn't necessarily "real OE".
Dazed and Confused,
chris
Dazed and Confused,
chris
