Is it worth cleaning the throttle body? My truck never has any idle problems. But at the same time she has 180,000https://www.tacomaworld.com/threads/how-to-throttle-body-cleaning-2005-v6.94203/
But i use the handle of a screwdriver to hold the butterfly open.
I take the maf sensor off to clean it.
I dont use a bunch of bailing wire to hold crap up.
I use a microfiber towel.
I undo 4 bolts for other side of tb, and carefully leave hoses on.
Truck may die 1st time u reattach errything.... dont worry bout it, just restart.
Yes, i would say so.Is it worth cleaning the throttle body? My truck never has any idle problems. But at the same time she has 180,000
Just curious, what would happen if I chose not to clean it...?Yes, i would say so.
It gets dirtier.Just curious, what would happen if I chose not to clean it...?
How do you fit a mop in your throttle body?You might surprised, but home cleaning stuff like bestproductspro is doing fine for me. I personally can recommend, however, not suitable for all cars.
Mini mopYou just force it in there. It’ll go. And I’m sure your truck will never run the same. Or probably ever run again.
Spit on first!How do you fit a mop in your throttle body?
What product? The mop?I used this product and watches as black carbon melted away like butter! Recommended for every person with a fuel injected car.
Air Intake CleanerWhat product? The mop?
