TPMS with aftermarket wheels
ScreaminYoda
Can't get my tpms light to go off after new wheels with tpms was installed. Any suggestions? Tried the reset button numerous times.
I thought I read somewhere where it said they would automatically communicate with the truck but don't seem so. I knew someone here would know
From what I’ve ever heard, they have to be connected to the truck electronically once they are installed. They will say that hey will work, but the installer has to use a computer to sync them. You might need to take them back to whoever installed them and have them connect them for you.
I hope they came with wireless ones ,cuz you need a lot of extra wire on the hard wired ones so it does. not wrap around the axle ? Just sayin'.
If you reuse the tps in another set of rims do you have to make sure it goes back on the same axle ? And. if you rotate does it just relearn the wheel ?
