Valve stem
John dev
Sup guys
I just ordered set of rims and tires
But it doesnt come with the sensored valve like what i have on my Toyota
Can i use regular valve stem
Or i need to use toyota sensor valve stem
The guy i ordered it from suggested i removed the valve stem on the original tires and put it on the new wheels
You should have the original valve stems switched over to your new rims. If not, your tire pressure light will remain on. It’s a cheap switch at Discount Tire.
Are those things expensive?
I wanna be able to use my stock tires at any given time also
I had new tires put on my wife’s Sequoia and it needed new stems. They charged $20 each stem.
No, I got the stems at Discount Tire. The old stems had died, so I bought new stems when I got new tires. They were cheap and programmed to the truck for $20 each.
I need to get the same valve stem as the stock one so their both the same no need to program i guess
