Water in Head Lights
First post on TW, looking for some new headlights that don't get water in them. I had the OEM ones, and then the stealership replaced them but are no longer under warranty and they got water in them again. Can anyone suggest a company that makes quality head lights?
Honestly, oem.
My 06 never leaked, my current 10s havent leaked either.
Aftermarket has **** optics, and they leak on the regular unless a bead of ge silicone ii is run between the 2 halves.
Make sure u have all ur bulbs seated correctly, and the breather are there. Should look like rubber elbows. Also insure your using the rubber boot and its seated around the base of the bulb.
