K kayakanu New Member Mar 9, 2018 #1 have the chance to swap the base stereo for a 2014 oem touchscreen for a '14 taco....will be feasible?? Thanks all
B Bogunn Well-Known Member Mar 9, 2018 #2 kayakanu said: have the chance to swap the base stereo for a 2014 oem touchscreen for a '14 taco....will be feasible?? Thanks all Click to expand... The size of the head unit is probably different so you’ll have to do a little cutting and adjusting.
whippersnapper02 Negative Nancy Mar 9, 2018 #3 A friend swapped later headunits to his 07. You may need wiring adapters.
kp.taco Well-Known Member Mar 9, 2018 #4 I've seen it done. I don't know if u will need the 14 vents or not. And yea I'm sure the plugs are different.
D Dec1968 Member May 20, 2018 #5 kayakanu said: have the chance to swap the base stereo for a 2014 oem touchscreen for a '14 taco....will be feasible?? Thanks all Click to expand... Go aftermarket. You'll get more options and flexibility.
