100% Full Synthetic Oil , 0W-30 in place of 5W-30 engine oil.
Rambo
I have switched to a 0W-30 Major Brand Top Tier 100% Fully all Synthetic Oil for better fuel economy,quicker oil lubrication at start up, more piston ,Ring, and Piston Skirt, and lifters and cam lobes lubrication and protection. Lubricates tighter tollerences . I checked with all as Mobil1,AMSOIL,Castrol,and a few others on my 2013 4.0 V6 Toyota Tacoma PreRunner DCLB A.T. and all say it is safe and better to use than 5W-30 and 10W-30 Synthetics Oils ! Quicker cold start and faster lube in hot enviroments. Try it out and check with Oil Manufacturers also!
That will work!!! Have been using NAPA/ Valvoline in my 09 Tacoma 2.7l 4 cyl. Every quart you buy... NAPA gives to our VETS :))
Wut filter?
I use synthetic royal purple 5w-30 high mileage (since my truck has almost 200k) and I get my oil filters from the dealership. I personally thinks that's the best oil for your truck.
Same filter... oem, i just happen to be a mobil fan. Not dissing any others, or saying 1is better than other.
Just personal decision is all.
Using AMSOIL Signature Series 0W-30 100% Full Synthetic, change with a new filter every 10,000 -15,000 miles !
Nice... have u sent anything off to blackstone?
Yes, No wear an Tear, Oil is good for 25,000 miles,but,I don't let it stay past 10,000 miles tops!!!! Just sayin,want to stay safe and not be sorry! Old School heavy Equipment and Truck and Diesel Tech since 1976!
Smart move.
Immediately after using Royal Purple, I noticed a drop in the rpm gauge. Normal rpm is around 3500 before R.Purple and it's now maintaining around 2500. The ride does seem and feel smoother. I'm no mechanic guru and a bit iffy about the situation. Hope I didn't mess anything up.
It rides smoother?
o_O
3500, thats what, 80mph?
There should not be an RPM drop. I don't see 3500 at 80.
Sounds like I got something to worry about. 3500 rpm is roughly about 85-90ish on a 40 mile commute. I tend to have a bit of a lead foot from time to time. But there's definitely a drop in rpm and that's from Mobile 1 to Royal Purple. Guess I have researching to do when I return from Japan.
If you have a lead foot you may not be letting the converter lock up.
