2008 oil change capacity?
Discussion in 'Maintenance' started by Tosscobobble, Dec 21, 2020.
  1. Tosscobobble
    Tosscobobble New Member
    I've had my truck since it rolled off the line, only 3 miles on it.
    It has almost 250,000 miles on it, with regular oil changes.
    Every time, it's taken 6 quarts of oil with each change... Until this last time
    This place claims it only needs 5 1/2 quarts.
    Just for peace of mind, how much does that 1/2 quart matter?
  3. Killowatt
    Killowatt Active Member
    5.5qts gets the level midway between the marks, I use 6qts and it fills to top mark. Have the trans cooler and use the larger filter.
    I like having more than the minimum amount.
    Sent from my SM-G965U using Tapatalk
  4. OP
    Tosscobobble
    I've never had a place short me a 1/2 quart before... Annoying. The place has good reviews, but if they're skimping on something simple... What else are they doing?
  5. dasa
    dasa Member
