2008 Toyota Tacoma 4WD light flashing, need help
heineken
Hello all, this is my first post to this forum. I recently purchased a 2008 Toyota Tacoma V6 3.0 Liter 6-speed 4x4 and am having issues with the 4WD. It began with the 4WD light and 4LO lights flashing on the dash when the key was turned to the "On" position. I would hear the 4WD ECU click twice, and then the lights would start flashing immediately. When this occurs, there is no response in the 4WD system to the switch being turned to 4HI or 4LO.
At some times when I turned the key to the On position, the lights would not flash. When this occurred, the 4WD system worked flawlessly. It would immediately lock into 4HI or 4LO accordingly, and back to 2HI when the switch was turned back. I could hear both the Tx-case actuator and ADD actuator lock into place, the 4WD green dash light would illuminate, and everything worked great. However, for no rhyme or reason the light would flash at another time (could be later that day, or the next day, no rhyme or reason to it). At this point I thought it could be issues with bad connections in the ADD actuator, so I bench tested and soldered the contact points. Again, it would intermittently work, but most times the lights just flashed.
Eventually I replaced the ADD actuator, but it still did not fix the issue. I inspected the transfercase actuator, and it was seemingly on its last legs. Some corrosion on the contact points and the motor didn't have quite enough power to move the transfercase rod when power was applied directly to the Tcase actuator. I got a used on at a salvage yard that was in great condition. Bench tested proved it worked. I installed it, applied power directly, and it would move the transfer case rod to the 4LO position and back again without issues. However, the light was still blinking. I triple checked that the ADD actuator was in the 2HI position, that the transfer case was in 2HI position, and that the transfer case actuator was in 2HI position. I also confirmed that the position sensors were working correctly, and they were.
I took it to the dealer so they could trouble shoot. Needless to say they spent very little time on it and recommended replacing the transfercase. When they tested at the ECU the TL1, TL2, and TL3 were all showing 12.5 volts of power when the switch was in the 2HI position. According to the pdf attached, this should not be occurring. However, when I test the limit switches at the transfercase actuator they are working appropriately. Not sure if this is a bad ECU, a short in a wiring harness somewhere, or something else. I have not completed the entire testing of the ECU, been short on time lately, but that is my next step (or just replacing it outright). I have a couple of questions:
To replace the 4WD ECU, does it have to be calibrated to the new vehicle when installed? Are there specific models for different Tacoma trucks, or are they generally universal?
Any input on testing the ECU further, or other suggestions of things to look at?
When I apply power directly to the ADD actuator it locks immediately, and when I reverse polarity it unlocks. Same with the Tcase actuator, it goes all the way to 4LO and then back to 2HI when I apply power directly to the pins in the actuator. It seems that everything is in good mechanical condition, hence why I suspect the ECU or a short in the wiring.
All grounds look good. Inspected the fuses and they are also good.
Any help or guidance you can offer is appreciated. I have a lot of hours put into resolving this, and it is starting to really frustrate me. Thank you again.
  • 4x4 troubleshoot guide.pdf
Hey, good info. Sorry your used purchase has an undisclosed gremlin. You seem to have a good grasp of the situation. A bad ECU?.. Doubtful but?.. Junkyard swap only real way to test cheaply. I believe there are a total of 4 motors/actuators though that could be bad/intermittent. The ADD and Transfer case High/Low hardware, and the 2 units that engage, lock the front drive shafts to ea front hub. I've never heard of a 4WD ECU needing to be Calibrated to a specific vehicle.
I have the same vehicle, pull a trailer and a boat 6x a year. On Occasion.. it doesn't want to go In or Out of 4WD in In/Out of High/Low. You can hear it trying but it just 'buzzes' and flashes the Error light. Come to complete stop, FLAT ground, Neutral, and try again. Have never had a problem beyond that. Please post a solution. Thanks
I know this is an older post but has anyone been able to resolve this issue? I also have 08 tacoma, A/T, 4.0 and having almost same problem. My High 4wd and 4Lo light come on randomly, illuminating solid on dash. When this happens the 4wd selector will not work. You may be in 2wd drive when it comes on and then you can not use/switch into 4wd. Also if in 4wd and both lights come on you are stuck in 4wd. You can turn truck off and it will sometimes unlock on its own and lights will be out when you restart truck. So far checked wiring, cleaned and checked all plug ins, replaced the rear diff lock actuator, checked and cleaned shift actuator on transfer case, checked front ADD actuator. swapped out the two shift sensors with two I had on another transmission, replaced the 4x4 ECU, checked and adjusted shift position switch on transmission. Have not checked knob/selector switch on dash. When it does work it works flawless...but when lights come on on the dash....its a big pain in the butt! I've been told it could still be the ADD actuator, I have another transfer case I could put in but I really don't think thats it. Also tried the trick, unhook battery and touch cables together to reset ECU. Cleaned and checked battery terminals. Checked grounds. You can drive sometimes for 200 miles no problem. Shut truck off to get gas, start truck back up and lights are on or you drive 5 miles and lights just pop on while going down the road. Anyone have any ideas please pipe in. All help will be appreciated.
