2013 Tacoma TRD sport 6 speed manual transmission
Well I was wondering if anybody has a problem or is just me every time I shift to gear 2 it makes some sort of noise am I not pressing the clutch to in or am I not doing it at the right time there be times it don't make it like I shifted perfect but times when it sound different no grinding noise though and I tend to stall how can I stop that
Are you shifting the sane way through all gears? If you are take it in and have them look at it. Are you shifting to early and not having the RPMs where they need to be? If you are stalling in 2nd sounds like to are shifting at a Cary low RPM.
Dumb auto correct. Same, very
When you push in the clutch the RPM gauge should jump for a second wait for that and then shift
