2015 Tacoma TRD PRO
You should be able to see body spacers (unlikely). Probably too new for rear springs to be sagging (unless it was used for seriously heavy duty towing). I’d be guessing gas shocks in the rear are shot or new shocks only in the front. Am I wrong here guys?
Welcome to the forum.
Look in the front coil/spring if there is a hockey puck looking thing in them it’s got a spacer/lift in front. You can give it the bounce test in back to check the shocks. Let use know what the dealer says if you go in.
The dealership I bought it from told me that most tacomas sit lower in the back. And I did some digging and found out that from the factory the front has 2 in lift where the back end has a 1.5 in lift
Never ever seen a newer stock truck with a higher front than back. Usually the back is higher with springs for loading. My guess is you have a spacer lift or aftermarket coilovers. Dealer is 100% wrong. Tacomas sit lower in front than back unless suspension is altered or worn.
