Adaptive Cruise Control in Manual 2018?
GrantF
Hi all,
Do the 2018 manual transmission Tacomas come with adaptive cruise control or is it only the auto? Can someone with a manual confirm?
Thanks
Hi all,
Thanks
Yes, can confirm that it does.
About the only thing the manual doesn't come with is terrain select and crawl mode.
It does, and when in gear and cruising it’s all normal but if you clutch in, and change gears or go to neutral I think you’ll need to hit SET again.
