Airing up tires after trail
Discussion in 'Off-Road' started by SCH, Jan 25, 2019.
  1. SCH
    SCH Well-Known Member
    What do some of you use to air up your tires after airing down. Had a small pump but it would take awhile to air back up the tires. Looking for something that doesn’t take a half hour to air back up.
  3. whippersnapper02
    Tacomania, B-Man, Crawdad and 2 others like this.
  4. OP
    SCH
    That looks like a good pump. Might have to try it.
    Tacomania, B-Man and whippersnapper02 like this.
  5. OR17TRD
    Tacomania, B-Man and Crawdad like this.
  6. Crawdad
    Crawdad Well-Known Member
  7. OR17TRD
    About 1-2 min per tire. It’s not super fast or powerful but it worked on 285/75/16’s and it’s worked on 275/70/18’s. I do one tire let it sit for a few minutes to cool down then do another. It’s about a 15 min process to do all 4. You could probably do them back to back but I don’t want to burn it out.
    Crawdad and B-Man like this.
  8. Bluegrass Taco
    Bluegrass Taco Active Member
    Viair 400P. I did the C02 thing for a couple years, which was excessive weight and takes up valuable space compared to the VIAIR compressor. When we go on longer trips, space is at a premium. It's also faster than my old C02 set up. (Relatively small regulator) With my old broken down body, it takes longer to get up and down off the ground than it does to inflate the tire!
  9. Steepside
    Steepside Member
    ARB Twin compressor with an Indeflate dual tire fill kit.
  10. Tacomania
    Tacomania Well-Known Member
    Same here, but without the fancy shmancy indeflate kit
    OR17TRD and B-Man like this.
  11. OR17TRD
    Tacomania and B-Man like this.
  12. Tacomania
    OR17TRD likes this.
  13. bryangreene
    bryangreene Active Member
    I know I have seen this before somewhere, but not really sure where. Basically what I'm looking for is a 4 way splitter that is connected to your tires and you have one central point for either inflating or deflating your tires. Plus then after letting it sit for a moment all 4 tires will equalize in pressure.
  14. GREENBIRD56
    GREENBIRD56 Member
    My wife's uncle came back from Namibia talking about a Hilux diesel "Bakki" flatbed used by his outfitter. They had a large high pressure truck tire strapped to the headache rack - and a jumper hose to refill the tires after a cruise in the Kalahari.
    Cape taco, B-Man and Crawdad like this.
