Belt
Discussion in '2005 - 2015 Toyota Tacoma' started by jk252, Jan 6, 2019.
  1. jk252
    jk252 Well-Known Member
    What could cause my belt to show wires. I just replaced it 7k miles ago. Could the tensioner cause it? Every time when I crank it up it makes a noise
  3. steeltoe
    steeltoe Member
    What year taco ?
  4. OP
    jk252
    2006, i have a small leak from the engine could that caused it?
  5. Crawdad
    Crawdad Well-Known Member
    Pictures would help.
    Positive that the belt wasn't off a groove on a pulley when installed?
    B-Man likes this.
  6. Ricks2012
    Ricks2012 Well-Known Member
    Belts don't like oil. Was it aligned properly on the pulleys. Are all the pulleys themselves lined up?
    B-Man likes this.
  7. OP
    jk252
    I put the belt by my self on. My motor is leaking oil slightly
  8. OP
    jk252
    You can see the wires on the belt
  9. kp.taco
    kp.taco Well-Known Member
    Pics.
    Ricks2012 and B-Man like this.
  10. Bojangles
    Bojangles Well-Known Member
    Bearings, improper alignment, wrong belt?
    Doubt the tensioner mechanism itself did it.. alot of supercharged guys are changing blower pullies and adding MORE pullies than normal to avoid belt slippage during boost. Some have BROKEN the tensioner arm for the blower serpentine belt and the belt itself has been either fine, or wrapped up after the fact the tensioner broke.
    Ricks2012, Bogunn and B-Man like this.
  11. JASN
    JASN Well-Known Member
    How about the belt that's been sitting on the auto parts store shelf for 10 years drying out and cracking just one of those things that make you go hmmmmmmmm
    Sent from my SM-G892U using Taco Forum mobile app
    B-Man, Ricks2012 and Bogunn like this.
