Bilstein 5100 and spacer fit 33s
Chasintail
I'm looking at getting the 5100s and a .75 spacer to get 3.25 in of lift. Will this be able to fit 285/70r17 (33s). I do not want to rub and I don't want to trim anything. Will they fit?
You might rub the uca unless you run wheel spacers or aftermarket wheels
I did a 3" suspension lift and the biggest tire you can get without any trimming is a 285/65/18(20) or a 265/70/18(20). I would suggest the 265 bc a 285 tire is a ten ply tire which ride like sh*t but it's a little taller than the 265. The 265 is a little bit wider. The rim you can go with a 0 mm offset bc any offset will cause rubbing
