Compressor question
Taco-Can
Does anyone know if you can run a 2-3 gal tank compressor off the outlet in the bed of the truck?
I find those small battery hookup units are pretty slow airing up after wheeling.
Does anyone know if you can run a 2-3 lbs tank compressor off the outlet in the bed of the truck?
Only one way to find out if it will work or trip it. ARB sells an onboard compressor. They work great and you can mount it under your hood.
I will see if I can borrow a small unit to try it out. ARB would be cool, but you can get a small 2-3 gal tank compressor for well under $200. I was thinking I could just secure it in the bed on trail days.
I will see if I can borrow a small unit to try it out. ARB would be cool, but you can get a small 2-3lbs tank compressor for well under $200. I was thinking I could just secure it in the bed on trail days.
Very true. Keep us posted.
