Drivers Side Taco Lean after lift
Discussion in '2005 - 2015 Toyota Tacoma' started by MattScatt425, Feb 12, 2018.
  1. MattScatt425
    MattScatt425 Well-Known Member
    Does having the drivers side taco lean create rubbing on turns?
  3. Bojangles
    Bojangles Well-Known Member
    Huh?
  4. Bojangles
    Not that ive seen or herd
  5. OP
    MattScatt425
    Gheeze I need to speed check I'm mean spell check
    OR17TRD likes this.
  6. 4wd
    4wd Well-Known Member
    First off, what kind of lift ? & a couple pics should be posted to look at issue...Makes it a lot easier & quicker too...
    Anyway, 'taco lean isn't going to cause rubbing , driverside low , pass side higher correct ?
    OR17TRD, Bogunn and Bojangles like this.
  7. OR17TRD
    That’s the Taco lean.
  8. Garrick
    Garrick Active Member
    Remove the steering column and keep the gas tank empty, no more lean!
    whippersnapper02 and Bogunn like this.
  9. 4wd
    Don't forget the battery...
    Garrick and Bogunn like this.
  10. TacoKen
    TacoKen Well-Known Member
    Mine had about 1/4 to 1/2 inch lean before I installed my Toytec 2 1/2 inch lift. I adjusted the left front shock 2 threads more than the right and lean is pretty much gone. Then had it aligned. No more lean.
    MattScatt425 and Garrick like this.
  11. OP
    MattScatt425
    Okay cool that's what I was thinking about doing just adjusting the left side to compensate thanks man!
