Engine shutter. Code - cyl 4 misfire.
816Tacoma
I'm sure this topic had been addressed and in advance, I did search the forum.
Basically, shuttering when I'm accelerating, tried holding the brake and giving it gas... So both in motion and under a load it shutters. CEL blinked 6 times and then remained on, off now. Code at AutoZone says cyl 4 misfire. Issue is intermittent.
I have to take the top and the fuel rail to replace the spark plugs and one coil, correct? And while I already have the thing apart... Shouldn't I just do all the coils?
Suggestions? Clean the MAF first to try? Bad tank of gas possible?!
Thanks fellow Tacos
Good advice^^^^^^.
Start simple first. I’d definitely swap coils and plugs. It’ll never hurt to replace them anyway.
Basic tuneup.
