Fab - Door Lock Alarm
georgedickelplz
Is there a way to increase the Beeping sound when a Fab is pushed to lock the door ??? As of now with my hearing handicap it's very hard to hear if the doors lock or not. If I'm not standing at the front or the back of the truck to catch the lights blinking I would never know the doors were locked. My previous Truck ( Frontier) had a loud beeping sound when Fab pushed so something should be out there to remedy this problem. Please Advise. Thanks
You could probably use a piezo tweeter from a BMW or any louder car. Unfortunately this simple part may cost more than normal.
Welcome.
Still new to the taco, so I'm not exactly sure the location/complexity of it but I replaced the one on my BMW and was very simple plug and play. It's fairly simple tech, so I can't imagine it would be too hard to replace on your truck. I'll leave it to the experts to chime in.
I don't remember for sure, but this might be an option in the Carista app. You'd need a bluetooth OBD2 adapter as well, and the app is expensive but there is a free trial. Otherwise, the dealer should be able to change the volume, if it is in fact an adjustable setting, but unless they do it for free, the carista app would probably still be cheaper. I can't guarantee, but I thought I saw it in Carista. Just search for caristaapp, I can't post links yet.
The website doesn't show support for the Tacoma, but I can confirm my 2018 allowed me to change settings like the seat-belt reminder and how many blinks the tap-turn signal was.
Here's a list of what the app can change from a post on TW https://www.tacomaworld.com/threads/dyl0ns-tuned-build.457451/#post-13517316
Doors / Windows / Remote
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking/unlocking with remote
*YES* / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / *MAX*
Warn (beep) when door can't be locked because it's still open
*YES* / NO
Warn (beep) when sunroof is still open when locking doors
*YES* / NO
Panic function on remote
*ENABLED* / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Unlock doors via physical key
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Auto-lock all doors
DISABLED / *WHEN SHIFTING INTO GEAR* / WHEN VEHICLE STARTS MOVING
Auto-unlock all doors
DISABLED / *WHEN SHIFTING INTO PARK (P)* / WHEN DRIVER'S DOOR IS OPENED
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / *5 SECONDS*
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Instruments / Display / Dings
Engine start indicator
*ON* / OFF
Display odometer after ignition is turned off for…
30 SECONDS / 1 MINUTE / 10 MINUTES / *OFF*
Key-in-ignition ding sound
*SLOW* / MEDIUM / FAST
Ding when headlights are left on
YES / *NO*
Seat belt warning ding (driver)
ENABLED / *DISABLED*
Seat belt warning ding (front passenger)
Lane-change turn signal auto-flasher count
OFF / 3 FLASHES / *4 FLASHES* / 5 FLASHES / 6 FLASHES / 7 FLASHES
Remote low battery warning
*ON* / OFF
Rear parking sensor range
NARROW / *WIDE*
Mute parking sensor when stationary for more than 3 sec.
YES / *NO*
Parking sensor beep volume
1 / 2 / *3* / 4 / MAX
Activate parking sensors in neutral (N)
*YES* / NO
Enable rear parking sensors when in neutral or forward gear
REAR / REAR CORNER / *OFF*
Dash display mode
*ALL* / UNDISP
Lights
Daytime running lights
*ON* / OFF
Coming-home lights duration
OFF / 30 SECONDS / *60 SECONDS* / 90 SECONDS
Auto headlights activation threshold
*DARKEST* / DARKER / NORMAL / LIGHTER / LIGHTEST
Instrument lights dimming sensitivity
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when you unlock doors
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Interior light control
Heater & A/C
Temperature dial calibration
-2°C / -1°C / *NORMAL* / +1°C / +2°C
Auto-increase blower speed when front defroster is on
YES / *NO*
Auto-turn on A/C when AUTO button pressed (if needed)
*YES* / NO
Deactivate front defroster when AUTO button pressed
*YES* / NO
Open vents to outside air when ignition is turned off
*YES* / NO
Fan speed reaches its target…
SLOWLY / *NORMALLY* / FAST
